Upload all files except current date
fairudyn
Singapore
Hi there, just needed help on how could I edit my script to upload all files in a local folder except for the ones created on the current date
So basically I would want to transfer all my backups over to our remote server but on a daily basis leaving 1 copy of backup that is created on that day itself.
lcd C:\WEBBACKUP
cd /WebBackup/178
put -delete -transfer=automatic "*.zip"
Do you think if I changed it to this it will work?
lcd C:\WEBBACKUP
cd /WebBackup/178
put -transfer=automatic "*.zip" -filemask="*>=1D" *
Re: Upload all files except current date
If I understand your question correctly, then you have the condition otherway around.
It should be:
put *.zip -filemask="*<=1D" *
fairudyn
Singapore
It should be:
Hi Martin would this be correct if I choose to delete the rest except those created on the current date?
lcd C:\WEBBACKUP
cd /WebBackup/178
put -delete *.zip -filemask="*<=1D" *
This downloads and deletes all zip files created more than 24 hours ago.
