Task Scheduler/Scripting Basics Help
spaldingl
Hello, I'm very new to scripting. The underlying principles I understand, it's just the syntax I need some help on. All I need to do is create a task in the Task Scheduler that reuploads the same file from my computer to my Linux server every 30 minutes, essentially just overwriting it. I was reading over this article https://winscp.net/eng/docs/guide_schedule but got confused when it started talking about the arguments. Could someone tell me what exactly I need to type in the add arguments box in order to get it to upload the file to linux? I downloaded a script from WinSCP that I believe should accomplish this, just need to know how to translate that into the Scheduler arguments.
Script:
open sftp://ec2-user@ec2-servernumbers.compute-1.amazonaws.com/ -hostkey="hostkey=" -privatekey="C:\Users\privatekeypath" -passphrase="password" -rawsettings Cipher="aes,chacha20,3des,WARN,des,blowfish,arcfour" ConsiderDST=0
lcd "C:\Users\filepath\"
cd /usr/java/linuxpath/
put index.jsp
pause
fairudyn
Singapore
Hi I believe you would save your script as a .txt file. Then you will need to create a batch script to trigger your .txt file.
For example the script you listed you saved it as upload index.txt
Then you will need to create a .bat file from a notepad and save it as upload index.bat
On your task scheduler under the Actions Tab
Select Start a Program
And browse to your .bat script
You can leave Add arguments and Start in blank
Yes, you can save the commands to .txt.
But the point is that you then specify WinSCP.exe as the program to execute in the scheduler. As the article says:
* Browse for WinSCP.exe executable.
And use arguments like
/script=C:\path\to\script.txt /log=C:\path\to\script.log /ini=nul
Or you can use the /command and specify the commands directly on WinSCP command-line. But that may not be convenient, providing the small box in the scheduler.
