SessionOptions.SshPrivateKeyPath is set, but SessionOptions.Protocol
smarazzi62
italia
hi,
i'm trying to connect to ftp site using .net assembly with session option c# code generated by winscp ui, as follow
// Set up session options
Protocol = Protocol.Ftp,
HostName = "xxxxxxxxxx",
PortNumber = 21,
UserName = "xxxxxx",
Password = "xxxxx",
SshPrivateKeyPath = @"C:\Program Files\WinSCP\......PPK",
FtpMode = FtpMode.Active,
TimeoutInMilliseconds = 60000,
sessionOptions.AddRawSettings("ProxyHost", "xxx.xxx.xxx.xxx");
sessionOptions.AddRawSettings("ProxyPort", "1080");
// Connect
session.Open(sessionOptions);
// Your code
I can connect with winscp ui but i get the error
SessionOptions.SshPrivateKeyPath is set, but SessionOptions.Protocol is neither Protocol.Sftp nor Protocol.Scp.
when i use .net assembly in c# application.
Some suggestion?
thanks
Re: SessionOptions.SshPrivateKeyPath is set, but SessionOptions.Protocol
OK, so remove the SshPrivateKeyPath.
You probably have the key set in your GUI session settings. While GUI will ignore the key, if you set it for non-SSH session, the .NET assembly is more strict.
