Cannot copy .cfg file. Permission Denied
matt_tee
I am trying to copy a config file into emulation station on an Odroid XU4 using Winscp.
My problem started after booting an image (Wolfanoz) from my micro sd card onto my Odroid XU4, It says that the configuration file is missing or invalid.
After checking, I seems that the config file 'es_systems.cfg' contains no data...
So I have a copy config of the file that I need, so I attempted to SSH from my laptop to my Odroid XU4 (similar to Raspberry Pi), across to the Micro SD card containing the boot image, but I am getting the following message:
Cannot overwrite remote file
Error code: 4
Error message from server: Failure
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
I have tried to CHMOD permissions to 777 and tried to change properties manually to 777 (right click file and change permissions) - to no avail..
I am lost, can somebody please help me?
Thanks in advance
Matt
Re: Cannot copy .cfg file. Permission Denied
Are you able to overwrite the file using any other SFTP client?
