Can't get to menues
Peter_Vella
France
Can't get to menues
When the app opens the login opens automaticaly so I can't get to the menues files etc. If I close the login panal winspc closes
Re: Can't get to menues
While you can configure WinSCP not to close, when the Login dialog closes, there's hadly anything you can do in WinSCP window, if you do not login.
Anyway, see "Keep main window open when the last session is closed":
https://winscp.net/eng/docs/ui_pref_window
This is actually XY question (I've addresses your real problem in a response to your email).
