Help with scripting a file from computer to server daily
creinemann
USA
I am looking for help in generating a script that can do the following.
I have software that receives digital signals from orbiting satellites and converts them to viewable images (.jpg) the files are generated like this - UTM-2019-5-14-9-19-39-23_IR.jpg, UTM-2019-5-14-9-19-39-23_RGB_rainfall.jpg, and UTM-2019-5-14-9-19-39-23_IR.jpg By date and type of image. Typically 6-10 files per day, and automated. The Path to the file is C:\Meteor\meteorfinal\UTM filename.jpg.
What I would like to build is a script that would upload ONLY the most recent 4 or 5 files at a certain time of day, say 11:30 am local, to an ftp server I have, BUT, I would like the filenames to be changed on the server to overwrite the existing files so that my website shows only the current days images (The server files could be named like Meteor1.jpg, Meteor2.jpg, Meteor3.jpg, etc.
Is this something possible?
Any and all help needed. Example image attached.
Carl
Re: Help with scripting a file from computer to server daily
For a such a complex task, you would have to use WinSCP .NET assembly, from e.g. a PowerShell script.
Start with:
https://winscp.net/eng/docs/script_upload_most_recent_file#library
But modify it to select N files:
Select-Object -First N
And then loop over the found files, like this example does:
https://stackoverflow.com/q/29787005/850848
Though you will want to upload them and you will want to change their target file name.
creinemann
USA
I was able to come up with this using Windows Task Scheduler
/log="C:\Users\yourwinuser\Documents\WinSCP.log" /ini=nul /command "open ftp://USERNAME:PASSWORD@yourftpsite.com" "put -latest C:\Users\ yourwinuser \Downloads\MeteorImages\* /public_html/wxtoimg/" "mv public_html/wxtoimg/treated*.jpg public_html/wxtoimg/meteor.jpg" "exit"
I would like to do this for three files, would I have to add a command for each type of file to get it to upload the three most recent versions of the image? And how do I specify under the
-latest
the three most recent files?
Thanks for your suggestions
Start with:
As implied by my previous answer, you cannot implement this (selecting N latest files) using a simple scripting. Scripting can select one latest file only.
