The system cannot find the path specified
oxojeck
I use WinSCP version 5.15.1 (Build 9407), sublime text 3, windows 10. If I open file, edit and save, then I get an error: "Unable to save C:\Users\...\Temp\scp31723... Error: The system cannot find the path specified." But there no folder scp31723. My preferences:
Editors - https://prnt.sc/no98cy
Storage - https://prnt.sc/no98rw
Thanks in advance!
Re: The system cannot find the path specified
Uncheck the "External editor opens each file in separate window".
Or did you have any reason to check it?
oxojeck
Thanks! It helped.
