Download files
Blisk
Slovenia
Download files
how can I make a script to download files from remote server, to local server.
I have folders and subfolders and files in all of it and want exact copy to download to local server.
I know how to upload but can't download files and folders.
Can someone help me with this, please ?
Blisk
Slovenia
Here is my uplod script, but don't know how to make it download?
On these links there is no download!
option batch abort
# Connect
open sftp://username:password@192.168.333.191/ -passive=on -neweronly -hostkey="ssh-rsa 2048 fc:16:80:99:38:ef:c6:7d:22:9a:23:59:17:93:9e:88"
# Change remote directory
cd /archive/files
# Force binary mode transfer
option transfer binary
# Upload the file to current working directory
put D:\inf\dll\DVD
# Disconnect
close
# Exit WinSCP
Blisk
Slovenia
Thank you, I have manage to make script to upload, but it doesn't
recognise any switch
when I put -neweronly -resume
it say
unknown switch "neweronly"
unknown switch "resume"
open sftp://username:password@192.168.333.191/ -passive=on -neweronly -resume -hostkey="ssh-rsa 2048 fc:16:80:99:38:ef:c6:7d:22:9a:23:59:17:93:9e:88"
Also when I download text file it loose lines.
All is in one line and it should be in 10 lines for example.
-neweronly and -resume are switches of the put command, not open.
So it's
put -neweronly -resume ...
The file most probably has unix line endings, and you open it in a editor/viewer which does not support them (like Windows Notepad). You can add -transfer=ascii switch to fix that.
