Versions after 13.9 won't launch for me in Windows
bathsheba
Versions 15 and 15.1 hang on launch for me, apparently forever.
Windows 10 Pro, up to date.
Not sure how to find out what is happening, task manager shows no CPU or disk usage.
I can't send a screenshot right now because I need to have a working version installed in order to work, but if it would help I can get that at a quieter moment.
Thanks,
Bathsheba
b@bathsheba.com
Re: Versions after 13.9 won't launch for me in Windows
bathsheba
OF COURSE NOW IT WORKS
The debug version launched fine, and of course now when I install 15.1 again, it works too.
Problem solved. Log file attached for completeness.
Thanks,
Bathsheba
  • WinSCP3684.zip (238.62 KB, Private file)
