Generate session URL/code decode password to plain text
ToldaCZ
I see security vulnerability. Generate session URL/code is able to decode encrypted password to plain text.
BR
ToldaCZ
Re: Generate session URL/code decode password to plain text
This is rather broad post.
What "encryption" are you referring to?
Are you using master password?
ToldaCZ
Master password partially fix topic. See picture
Thank you
Without a master password, passwords are not protected (cannot be). They can be retrieved anytime. The "generate code" functionality makes it only bit easier. But that's actually a plus, as it makes it clear to everyone that the passwords are not protected.
See also
https://winscp.net/eng/docs/security_credentials
https://winscp.net/eng/docs/faq_password
