Batch file needs to be run as administrator to work
rajitha1114@...
Hi guys,
When I run my batch script, the cmd window opens & closes. It doesn't download the files.
But when I type the same commands in a command line (Without admin privileges), it executes successfully. And also, when I run the batch file as administrator, it works.
Can someone point me what I am doing wrong? Following is my simple script,
winscp.com /command ^
"open ftp://xxxx:pw@mysite.com/" ^
"option confirm off" ^
"get xpress.zip" ^
"put C:\Boodles\xpress.zip" ^
"get xpress_qb.zip" ^
"put C:\Boodles\xpress_qb.zip" ^
"exit"
Re: Batch file needs to be run as administrator to work
Add pause at the end of the batch file to see its output (including any errors).
rajitha1114
Sri Lanka
Hi Martin,
Thank you so much for your response.
Even though I add a pause, it still closes. But surprisingly, it works when run it as admin.
Following is the edited script,
"get dkxpress.zip" ^
"put C:\Boodles\dkxpress.zip" ^
"get dkxpress_qb.zip" ^
"put C:\Boodles\dkxpress_qb.zip" ^
pause
"at the end of the batch file", not at the end of WinSCP command-line.
    "get xpress.zip" ^
    "exit"
pause
