Problem Running Poweshell script as Shceduled task
johnwade01
Runs fine if ran from desktop. I have sched task set to run as same user.
I have edited IP and Username for security purposes.
I have found this article but not sure how it applies to using the dll vs the exe "https://winscp.net/eng/docs/faq_scheduler"
****PS Script
$start = Get-Date -format "dd-MMM-yyyy HH mm"
$fileout = "Output.csv"
$logfile = "c:\ConnectScripts\myScript.log"
CD \ConnectScripts
Add-Type -Path "C:\ConnectScripts\WinSCPnet.dll"
try{
# Set up session options
Add-content $logfile -value "Begin FTP"
Add-content $logfile -value "Create Session"
HostName = "0.0.0.0"
UserName = "UNAME"
SshHostKeyFingerprint = "ssh-ed25519 256 sBvf50pmJKOpC6pvDBDYbTQOP1PQ2DZhwKDQlFXAUPI="
SshPrivateKeyPath = "C:\ConnectScripts\SCPKEY.ppk"
$sessionOptions.AddRawSettings("AgentFwd", "1")
$sessionOptions.AddRawSettings("FSProtocol", "2")
try
$session.SessionLogPath = "C:\ConnectScripts\Session.log"
# Connect
# Your code
$session.PutFiles("C:\ConnectScripts\" + $fileout, "/dropoff/*").Check()
finally
$session.Dispose()
catch
Add-content $logfile -value "Error: $($_.Exception.Message)"
**** Exception from Powershell log
Error: Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
Using username "UNAME".
Authentication failed."
*****Session.log
. 2019-04-15 10:08:57.242 --------------------------------------------------------------------------
. 2019-04-15 10:08:57.242 WinSCP Version 5.15 (Build 9365) (OS 6.2.9200 - Windows Server 2012 Standard)
. 2019-04-15 10:08:57.242 Configuration: nul
. 2019-04-15 10:08:57.242 Log level: Normal
. 2019-04-15 10:08:57.242 Local account: GIA\administrator
. 2019-04-15 10:08:57.243 Working directory: C:\Program Files (x86)\WinSCP
. 2019-04-15 10:08:57.243 Process ID: 2140
. 2019-04-15 10:08:57.243 Command-line: "C:\Program Files (x86)\WinSCP\winscp.exe" /xmllog="C:\Users\administrator.GIA\AppData\Local\Temp\wscp6EB0.01FE8351.tmp" /xmlgroups /xmllogrequired /nointeractiveinput /dotnet=5.15.0 /ini=nul /log="C:\ConnectScripts\Session.log" /console /consoleinstance=_28336_31118057_311
. 2019-04-15 10:08:57.243 Time zone: Current: GMT-5, Standard: GMT-6 (Central Standard Time), DST: GMT-5 (Central Daylight Time), DST Start: 3/10/2019, DST End: 11/3/2019
. 2019-04-15 10:08:57.243 Login time: Monday, April 15, 2019 10:08:57 AM
. 2019-04-15 10:08:57.243 --------------------------------------------------------------------------
. 2019-04-15 10:08:57.243 Script: Retrospectively logging previous script records:
> 2019-04-15 10:08:57.243 Script: option batch on
< 2019-04-15 10:08:57.243 Script: batch on
< 2019-04-15 10:08:57.244 Script: reconnecttime 120
> 2019-04-15 10:08:57.244 Script: option confirm off
< 2019-04-15 10:08:57.244 Script: confirm off
> 2019-04-15 10:08:57.244 Script: option reconnecttime 120
> 2019-04-15 10:08:57.244 Script: open "sftp://UNAME@0.0.0.0" -hostkey="ssh-ed25519 256 sBvf50pmJKOpC6pvDBDYbTQOP1PQ2DZhwKDQlFXAUPI=" -privatekey="C:\ConnectScripts\SCPKEY.ppk" -timeout=15 -rawsettings AgentFwd="1" FSProtocol="2"
. 2019-04-15 10:08:57.244 --------------------------------------------------------------------------
. 2019-04-15 10:08:57.244 Session name: UNAME@0.0.0.0 (Ad-Hoc site)
. 2019-04-15 10:08:57.244 Host name: 0.0.0.0 (Port: 22)
. 2019-04-15 10:08:57.244 User name: UNAME(Password: No, Key file: Yes, Passphrase: No)
. 2019-04-15 10:08:57.244 Tunnel: No
. 2019-04-15 10:08:57.244 Transfer Protocol: SFTP
. 2019-04-15 10:08:57.244 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2019-04-15 10:08:57.244 Disable Nagle: No
. 2019-04-15 10:08:57.244 Proxy: None
. 2019-04-15 10:08:57.244 Send buffer: 262144
. 2019-04-15 10:08:57.244 SSH protocol version: 2; Compression: No
. 2019-04-15 10:08:57.244 Bypass authentication: No
. 2019-04-15 10:08:57.244 Try agent: Yes; Agent forwarding: Yes; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2019-04-15 10:08:57.244 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2019-04-15 10:08:57.244 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2019-04-15 10:08:57.244 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2019-04-15 10:08:57.244 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2019-04-15 10:08:57.244 Simple channel: Yes
. 2019-04-15 10:08:57.244 Return code variable: Autodetect; Lookup user groups: Auto
. 2019-04-15 10:08:57.244 Shell: default
. 2019-04-15 10:08:57.244 EOL: LF, UTF: Auto
. 2019-04-15 10:08:57.244 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2019-04-15 10:08:57.244 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2019-04-15 10:08:57.244 SFTP Bugs: Auto,Auto
. 2019-04-15 10:08:57.244 SFTP Server: default
. 2019-04-15 10:08:57.244 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2019-04-15 10:08:57.244 Cache directory changes: Yes, Permanent: Yes
. 2019-04-15 10:08:57.244 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2019-04-15 10:08:57.244 DST mode: Unix
. 2019-04-15 10:08:57.245 Looking up host "0.0.0.0" for SSH connection
. 2019-04-15 10:08:57.245 Connecting to 0.0.0.0 port 22
. 2019-04-15 10:08:57.310 We claim version: SSH-2.0-WinSCP_release_5.15
. 2019-04-15 10:08:57.362 Server version: SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.8
. 2019-04-15 10:08:57.362 Using SSH protocol version 2
. 2019-04-15 10:08:57.362 Have a known host key of type ssh-ed25519
. 2019-04-15 10:08:57.407 Doing ECDH key exchange with curve Curve25519 and hash SHA-256
. 2019-04-15 10:08:58.023 Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them
. 2019-04-15 10:08:58.024 Host key fingerprint is:
. 2019-04-15 10:08:58.024 ssh-ed25519 256 39:a4:21:74:37:42:7a:81:08:46:78:47:db:d2:23:32 sBvf50pmJKOpC6pvDBDYbTQOP1PQ2DZhwKDQlFXAUPI=
. 2019-04-15 10:08:58.025 Host key matches configured key
. 2019-04-15 10:08:58.025 Initialised AES-256 SDCTR client->server encryption
. 2019-04-15 10:08:58.025 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2019-04-15 10:08:58.025 Initialised AES-256 SDCTR server->client encryption
. 2019-04-15 10:08:58.025 Initialised HMAC-SHA-256 server->client MAC algorithm
. 2019-04-15 10:08:58.151 Reading key file "C:\ConnectScripts\SCPKEY.ppk"
. 2019-04-15 10:08:58.151 Key file contains public key only
! 2019-04-15 10:08:58.151 Using username "UNAME".
. 2019-04-15 10:08:58.196 Server offered these authentication methods: publickey,keyboard-interactive
. 2019-04-15 10:08:58.196 Attempting keyboard-interactive authentication
. 2019-04-15 10:08:58.241 Prompt (keyboard interactive, "SSH server authentication", "Using keyboard-interactive authentication.", "Password: ")
. 2019-04-15 10:08:58.242 Disconnected: Unable to authenticate
Re: Problem Running Poweshell script as Shceduled task
That means your .ppk file is actually not a PPK file.
And it "Runs fine if ran from desktop" probably only because you have the matching private key loaded into Pageant (covered in the FAQ you have found).
