Folders no longer being remembered?
stuffdone
Florida USA
Used to be when I connect to a site and on local pane navigated to a folder for that site WinSCP would remember those locations.
Since last upgrade no longer remembers folders always opens to last folder locally ignoring what site I am connected to. Have had to go hunting for downloaded backup files from sites which I assumed were in the correct local folder but were actually in the folder for a previous connected site.
Settings save in .ini file.
Is there a new setting I need to make now to tell WSCP to remember my local folders as they relate to sites I connect to?
Re: Folders no longer being remembered?
I'm not aware of any such change.
Can you please post few screenshots and session log file documenting the problem?
Screenshots of these screens would help:
https://winscp.net/eng/docs/ui_pref_panels
https://winscp.net/eng/docs/ui_pref_panels_local
https://winscp.net/eng/docs/ui_login_directories
And also of the main window after you open the session.
stuffdone
Florida USA
Remembering local directories
I find the info very confusing.
Let me simplify what I expect as a universal setting that does not require that I make changes to every single logon since this should be DEFAULT for every site.
Each site has it's own local directory.
1. I click a domain to log into FTP.
2. It loads on local pane the directory for those files on my desktop.
3. It loads on remote pane the directory on server.
Note I have all the local folders saved but WinSCP for the most part refuses to switch when I open a new session. I almost (but not always) have to keep navigating to the correct directory the approving with SAVE. But still does not switch next time I switch sessions.
stuffdone
Florida USA
I have same problem
I also cannot get to save local folders. I did set then in Advanced under profile for each site but that does nothing.
Every time I log in to any site it always loads the last local folder and I have to constantly navigate to the correct folder each session.
This never used to be a problem so it stands to reason this fault resulted from an update.
Where can I download older versions that worked well. Why fix something that wasn't broken !!
Re: I have same problem
This is your own five years old topic. So what do you mean by your claim that it used to work, if you have the problem for five years already? If you want to get this resolved, please provide the information I've asked you for years ago.
