Synchronize Problem -special Filenames
sixta
Ebersberg
we try to synchronize a path (we know the path name is very special), script:
open ftp:bla….
option failonnomatch off
option batch continue
synchronize remote -delete -mirror "D:\Gemeinsame Ordner\4) ToDo Kroiß\sfirm\Banking\sf_dat" "/Gemeinsame Ordner/4) ToDo Kroiß/sfirm/Banking/sf_dat"
We get always the same error messages see winscp2.jpg.
When we look at the FTP-Server, the files exist locally and remotely see winscp1.jpg.
Why do we get the error messages?
  • winscpImg.zip (112.49 KB, Private file)
Description: zip-File containing winscp1.jpg and winscp2.jpg
Re: Synchronize Problem -special Filenames
Make sure you use the latest version of WinSCP and that your script file uses UTF-8 encoding.
See https://winscp.net/eng/docs/scripting#using_scripting
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
sixta
Ebersberg
Thank you for the quick reply.
I think it has nothing to do with UTF-8.
But looking exactly at the logfile, I got it. The user named the file with a leading blank.
Have a look at D:\datex\ Datenbank-..., there is a blank before "Datenbank..."
No idea how he managed it on a windows system ...
To proof this, I have isolated the files and got the following log-file:
Verbinde mit backup.serverkompetenz.de ...
Verbunden
Starte die Sitzung...
Sitzung gestartet.
Aktive Sitzung: [1] user@backup.serverkompetenz.de
failonnomatch   off
confirm         off
batch           continue
Vergleiche...
Lokal 'D:\datex' => Entfernt '/datex'
Synchronisiere...
D:\datex\ Datenbank-Inhaltsabgleich _20131025-1022.htm |         197 KB | 1155,9 KB/s | binary | 100%
D:\datex\ Datenbank-Inhaltsabgleich _20140114-1439.htm |           2 KB |  782,2 KB/s | binary | 100%
D:\datex\ Datenbank-Inhaltsabgleich _20150121-0831.htm |           1 KB |  623,8 KB/s | binary | 100%
D:\datex\a.diener.prf.lock |           29 B |  514,7 KB/s | binary | 100%
Fehler beim Löschen der Datei '/datex/Datenbank-Inhaltsabgleich _20131025-1022.htm'.
/datex/Datenbank-Inhaltsabgleich _20131025-1022.htm: Datei oder Verzeichnis nicht gefunden
A(b)brechen, (W)iederholen, Über(s)pringen, (A)lle überspringen: Überspringen
'/datex/Datenbank-Inhaltsabgleich _20131025-1022.htm' gelöscht
Fehler beim Löschen der Datei '/datex/Datenbank-Inhaltsabgleich _20140114-1439.htm'.
/datex/Datenbank-Inhaltsabgleich _20140114-1439.htm: Datei oder Verzeichnis nicht gefunden
'/datex/Datenbank-Inhaltsabgleich _20140114-1439.htm' gelöscht
Fehler beim Löschen der Datei '/datex/Datenbank-Inhaltsabgleich _20150121-0831.htm'.
/datex/Datenbank-Inhaltsabgleich _20150121-0831.htm: Datei oder Verzeichnis nicht gefunden
'/datex/Datenbank-Inhaltsabgleich _20150121-0831.htm' gelöscht
D:\datex\test.txt         |            0 B |    0,0 KB/s | binary |   0%
Sitzung 'user@backup.serverkompetenz.de' geschlossen.
Keine Sitzung
So can you attach (not post) your script for that? I do not see any Datex in your original script.
Here it is:
open ftp://user:password@server.de/
synchronize remote -delete -mirror "D:\datex" "/datex"
close
