Install manually Assembly witout use NuGet
JonnyGio
Hello to all!
How I can install manually Assembly witout use NuGet?
Regards,
JonnyGio
tattdogg
Minsk, Belarus
1. download WinSCPnet.dll + WinSCP.exe files
2. add dll file to the project references
3. add exe file to the project root (add item - existing item if we're talking about VS)
4. check that Build action is set to Content for the exe file
JonnyGio
Thanks for the support, I have another problem:
When I add dll file to the project references is return this Warning message: "Resolved file has a bad image, no metadata, or is otherwise inaccessible. Could not load file or assembly 'C:\*****\******\******\WinSCP-5.15-Automation\WinSCPnet.dll' or one of its dependencies. This assembly is built by a runtime newer than the currently loaded runtime and cannot be loaded" is not possible use the DLL.
Regards,
JonnyGio
JonnyGio
And what runtime are you using? Why don't you use a later/the latest?
Yes, the problem was a runtime, with a latest version the DLL is recognized.
Thanks for the support.
Regards,
JonnGio
