PuTTYgen key conversion
wrecclesham
Vancouver, Canada
I generated a public/private key pair using PuTTYgen, and that works great. This allows me to establish an SFTP connection using WinSCP.
Out of curiosity, I also tried getting the private key generated in cPanel at my hosting provider to work with WinSCP. I realize that cPanel does not create SSH keys in the .ppk format that WinSCP wants, so they must be converted using PuTTYgen.
Two questions:
1) What file extension should I save the private key from cPanel using? .pem? .txt? Does this even matter?
2) When I try to import my cPanel private key into PuTTYgen, why does it say, "Enter a passphrase for key"?
Whatever I enter here, including leaving the "passphrase" field blank, is rejected when I try to import my private key from cPanel!
Re: PuTTYgen key conversion
There's no standard extension for PEM keys. And indeed, it does not matter.
I do not know cPanel.
But according to this page:
https://web.archive.org/web/20200919160337/https://www.eukhost.com/kb/how-to-manage-ssh-keys-in-cpanel/
... There's "passphrase" field on the cPanel SSH Key Generator page.
(maybe the field got unintentionally autofilled by your web browser)
