Batch Rename Error
Hi_ImKyle
Batch Rename Error
When using the Batch Rename command, everything is all good till I tell it to continue and begin renaming files.
It tries to rename the first file but shows an error,
Error: Exception calling "MoveFile" with "2" argument(s): "/my/remote/file that does exist.mkv not found."
Not sure what to say other than the file does exist and I can rename them manually just fine. Batch would be better as there's a lot.
Hi_ImKyle
Testing things closely with a .NET project, your library reports that my file does indeed exist via "Session.FileExists", but "Session.MoveFile" thinks it doesn't
