Invalid access to memory - TCustomScpExplorerForm::SetDockAllowDrag
shane.campbell2@...
WinSCP 5.15
(00008CE3) TCustomScpExplorerForm::SetDockAllowDrag
(00089BEF) ntdll.dll
dennis.gnad@...
I just started WinSCP the first time after an upgrade from a previous version (sorry don't know which). Trying again, it started properly. This is Windows 10 Pro 64bit (1803), Intel Atom X5-Z8350, 4GB RAM.
WinSCP 5.15
(0007E19F) ntdll.dll
bill@...
WinSCP 5.15
Simple logged onto the server and opened up the icon for WINSCP and the error message occurred.
bharat25@...
WinSCP 5.15.1
(00083FFF) ntdll.dll
mann.krazy@...
WinSCP 5.15
Re: Invalid access to memory - TCustomScpExplorerForm::SetDockAllowDrag
Igor.Lazo@...
Right click on WinSCP icon on tasbar and then left click on WinCSP icon in the menu itself.
WinSCP 5.15.1
(00008CE3)
user@...
WinSCP 5.15.1
(00008CE3)
kasisap@...
WinSCP 5.15.1
kasisap@...
WinSCP 5.15.1
andrew.vickery@...
WinSCP 5.15.1
jacqelyn.e.lambert@...
WinSCP 5.14.4
(00008CEF) TCustomScpExplorerForm::SetDockAllowDrag
jeremy.mosley@...
WinSCP 5.15.1
harryhurley55@...
WinSCP 5.15.1
aadeyeri@...
<Not sure exactly what prompted this error, I was just exiting out of WinSCP when I noticed it.>
WinSCP 5.15.1
anthony.judge@...
WinSCP 5.15.1
tl.hall@...
WinSCP 5.15.2
pandas2019@...
Ошибка доступа к памяти - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.2
Ошибка доступа к памяти.
Трассировка стека:
(00087C8F) ntdll.dll
Эта программа мне блокирует полный доступ к FTP. Намертво просто убивает. Ни под root, ни под другим я не могу войти.
.jpg
andy@...
I clicked on the winscp icon and this appeared. So far, this has been the only instance of this error to occur.
WinSCP 5.15.2
(0008247F) ntdll.dll
asperanza@...
WinSCP 5.15
(0008402F) ntdll.dll
silviaistre@...
Acesso inválido à memória - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.2
Rastreamento de pilha:
minu.venkat@...
Just tried to open Winscp and it crashed with this error.
WinSCP 5.15.1
prpravda@...
WinSCP 5.15.2
Трассировка стека:
(000455C6) ntdll.dll.RtlRaiseStatus
jmh@...
WinSCP 5.15.1
aperlink@...
I opened Portableapps Winscp once, tried to connect to a site that was unreachable, behind a proxy. On connection timeout popup I clicked OK which closed WinSCP, instead of going back to initial screen, which is always annoying for me. After I started Winscp again via portableapps, I got the
Invalid access to memory errorStack trace:
(00008CE3)
And I needed to click OK several times before the initial login window showed up.
I'm not sure about session logs...
WinSCP 5.15.1
(00008CE3)
kubelka@...
Chyba přístupu do paměti - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.2
Chyba přístupu do paměti.
alok.agrawal@...
WinSCP 5.15.2
Kelleyjoe23@...
WinSCP 5.15.2
walter.frischknecht@...
Zugriffsverletzung - ungültiger Zugriff auf den Speicher - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.2
test.user@...
Launched WinSCP for first time after upgrading to Windows 10 1903, and .net 3.5/4.8 cumulative updates.
WinSCP 5.15.1
Kelleyjoe23@... wrote:
WinSCP 5.15.2
peter.luan@...
WinSCP 5.14.4
christian.vom.bruck@...
WinSCP 5.15
(00008CE3)
(00081D3F) ntdll.dll
isaiaherven@...
Happened right when I tried to launch the application
WinSCP 5.15.3
(00008CFF) TCustomScpExplorerForm::SetDockAllowDrag
1844588360@...
Stack trace: (00008CFF) TCustomScpExplorerForm::SetDockAllowDrag (0007E19F) ntdll.dl
WinSCP 5.15.3
无效的内存访问。
Re: Stack trace: (00008CFF) TCustomScpExplorerForm::SetDockAllowDrag (0007E19F) ntdll.dl
jan.koenraadt@...
Issue appeared as I clicked on the shortcut to open WinSCP. Not sure if it will happen again.
I did not include a screenshot as the alert only contained below Stack trace.
Hope this helps and thanks for this usually great tool!
WinSCP 5.15.2
kevin.herr@...
WinSCP 5.15.3
kevin.herr@...
This has been fixed.
kevin.herr@... wrote:
WinSCP 5.15.3
How did you fix it?
mailbox.abhishek.kumar@...
WinSCP 5.15.2
om@...
When I hace typed password
WinSCP 5.15.3
j.conca@...
Accès mémoire invalide - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15
Accès mémoire invalide.
Trace de la pile :
meclements43@...
Just started WinScp
WinSCP 5.15.3
nothing@...
WinSCP 5.15.3
thomasd.lindgren@...
WinSCP 5.15.3
constant@...
WinSCP 5.15.3
kurt.bonheure@...
Ongeldige toegang tot geheugen - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.3
Description: On dragging, the application freezes for a couple of minutes and shows the error. Afterwards we retry to drag and it works...
Re: Ongeldige toegang tot geheugen - TCustomScpExplorerForm::SetDockAllowDrag
olivia_hoover@...
WinSCP 5.15.3
bharat25@...
Happens on Wireless internet.
WinSCP 5.15.4
(00087D6F) ntdll.dll
markomaxn@...
Nieprawidłowy dostęp do pamięci - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.4
mferch@...
WinSCP 5.15.4
s.daute@...
WinSCP 5.15.4
arianaa30@...
WinSCP 5.15.4
pslaughter@...
WinSCP 5.15.1
arianaa30@... wrote:
WinSCP 5.15.4
klodvig105@...
This error appears whenever I set the computer to sleep after finishing the download and while using a VPN. I use SoftEther VPN at work and download files daily.
WinSCP 5.15.4
ed.dietrich@...
WinSCP 5.15.4
WinSCP 5.15.4
sam.collett@...
WinSCP 5.15.4
thibaultsacquet@...
This problem happened after I started the program, just after starting my computer. It is the first time it happens. The computer is partially managed by my company.
WinSCP 5.15.2
Trace de la pile :
josh.c.chin@...
WinSCP 5.15.1
john.c.howard@...
WinSCP 5.15.4
stefan.lindstrom@...
Ogiltig åtkomst till minnet - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.3
Ogiltig åtkomst till minnet.
Stackspår:
john.c.howard@... wrote:
WinSCP 5.15.4
josh.c.chin@... wrote:
WinSCP 5.15.1
deepali.dixit@...
WinSCP 5.15.5
(0008341F) ntdll.dll
rob.sijben@...
WinSCP 5.15.7
(00008D13) TCustomScpExplorerForm::SetDockAllowDrag
lee.vermont@...
installing on a laptop
WinSCP 5.15.9
kirru.chappidi@...
WinSCP 5.15.9
maureen.simoneau@...
After installation, clicked on client to launch it from start menu. This actually crashes the server (Windows Server 2016) and I have to recover from a snapshot. This is a virtual server using VMware.
WinSCP 5.15.9
zc@...
无效的内存访问。 - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.9
无效的内存访问。
(0008C85F) ntdll.dll
triin.samuel@...
I think I just opened WinSCP after resuming from sleep and connecting VPN. Might have also tried to drag the WinSCP view ever so slightly. But really not sure because I also did that to the program that I used to take the screenshot, so I might be mixing this part.
WinSCP 5.15.9
orlandeth@...
Acceso a memoria no válido - TCustomScpExplorerForm::SetDockAllowDrag
WinSCP 5.15.9
Traza de la pila:
mclark@...
Ran the latest round of Windows 8 updates.
WinSCP 5.15.9
(0003EF5E) ntdll.dll.ZwWow64CallFunction64
ulfindo@...
WinSCP 5.15.9
(0007E1AF) ntdll.dll
Re: Zugriffsverletzung - ungültiger Zugriff auf den Speicher - TCustomScpExplorerForm::SetDockAllowDrag
stina.frank@...
WinSCP 5.15.9
Stackspår:
