My External Editor autoselect no longer works if multiple file types are listed together
[Never mind - I forgot a
I used to be able to add multiple file types to Autoselection in the format
If I only put one file type in the autoselect - like
Do I now have to "Add" a new editor autoselect for each file type separately?
Or is the format required for multiple types of files now different than before?
Thanks!
; after one of the file types. 😝]
but that no longer works.*.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml; *.tpl *.twig
*.tpl - that works fine.
Thanks!
