troubles using "mv" moving folders to network path.
Greg LeBlanc
My script
option batch abort
open connection
mv "*.*" \\\\ess-raddon\\e\\phonecalls\\\*\.\*
fails and gives
Error moving file 'BUS4596555' to '\\ess-raddon\e\phonecalls\*.*'.
No such file or directory.
Error code: 2
Is it because i'm trying to move folds and not files?
Re: troubles using "mv" moving folders to network path.
I'm pretty sure that \\ess-raddon\e\phonecalls is not a valid path.
Open the folder in the remote panel of WinSCP GUI and use the exact syntax you see on the top of the file panel.
