Refresh directory after operation not working
44nonymous
"Refresh remote panel every" is disabled.
I have to manually refresh the directory after any operation like uploading a new file.
44nonymous
This is how to reproduce the bug:
- If transfer in background is enabled, refreshing the file list after any operation (upload, delete, etc) never happens.
- If transfer in background is disabled, a popup window shows, and after it closes refresh works fine.
Don't you have directory caching disabled?
https://winscp.net/eng/docs/ui_login_directories#directory_reading_options
44nonymous
Directory caching does not matter. I can reproduce the bug the same way with it enabled and disabled.
Enabling Transfer in background causes the problem. I had to try every possible setting until I found out what was causing the bug.
As I have asked you already:
In your log:
. 2020-02-13 05:37:12.921 Local directory: ...,  Cache: No
. 2020-02-13 05:37:18.062 Not refreshing directory, caching is off.
If you can reproduce the problem even with enabled caching (as you have claimed), please post a log file for that.
44nonymous
Come on give me some credit. I can't do it right now, I'm not using that computer.
Why do you need any caching to force refresh after any operation?. It makes no sense, but I TRIED IT TOO and it makes no difference.
Thanks.
It's just the way it is.
But I TRIED IT TOO and it makes no difference.
Post a log file for that.
44nonymous
It is not. If you disable Transfer in background (all cache options off), forcing autorefresh after any operation works perfectly.
You provide log of the opposite. I give up. This bug will stay forever, it was reported more than 5 years ago
That's true. I never claimed opposite. But for refresh after background transfer, the caching needs to be enabled. It's not a bug. It's the way it is implemented. I understand that you may not like it. But no one else have problems with it, so it's not likely I'm going to re-implement it.
