The value supplied is not valid, or the property is read-only. Change the value
sameer12
Pakistan
Hello Experts!
I am new to WinSCP and trying to get the latest files from FTP site. But I'm having errors. Please see what I am doing wrong a remote path or SshHostKeyFingerprint. I am attaching my remote path from WinSCP software.
New-Object : The value supplied is not valid, or the property is read-only. Change the value
At line:1 char:29
+ $sessionOptions = New-Object <<<< WinSCP.SessionOptions -Property @{
+ CategoryInfo : InvalidData: (:) [New-Object], Exception
+ FullyQualifiedErrorId : InvalidValue,Microsoft.PowerShell.Commands.NewObjectCommand
Server & Protocol information
Remote system = Windows_NT
File transfer protocol = FTP
Cryptographic protocol = TLS/SSL Explicit encryption, TLSv1
Encryption algorithm = TLSv1/SSLv3: ECDHE-RSA-AES256-SHA, 2048 bit RSA, ECDHE-RSA-AES256-SHA    SSLv3 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA1
Compression = No
Certificate fingerprint
5f:66:34:ad:e9:a9:8f:c2:60:79:d8:38:f6:da:7a:0b:68:d7:94:3C
Can change permissions = Yes
Can change owner/group = No
Can execute arbitrary command = Protocol commands only
Can create symbolic/hard link = No/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = No
Can calculate file checksum = No
Native text (ASCII) mode transfers = No
Additional information
The server supports these FTP additional features:
  LANG EN*
  UTF8
  AUTH TLS;TLS-C;SSL;TLS-P;
  PBSZ
  PROT C;P;
  CCC
  HOST
  SIZE
  MDTM
  REST STREAM
# Load WinSCP .NET assembly
# Set up session options
    Protocol              = [WinSCP.Protocol]::ftp
    HostName              = "10.162.12.15"
    UserName              = "Administrator"
    Password              = "Admin"
    SshHostKeyFingerprint = "ssh-rsa 1024 5f:66:34:ad:e9:a9:8f:c2:60:79:d8:38:f6:da:7a:0b:68:d7:94:3C"
try {
    # Connect
    # Transfer files
    $sourcePath = "/*.*"
    $destPath = "D:\ReplicationViaFTPServer\"
    $destPathNew = "D:\FTP\Data\"
    $transferOptions.FileMask = "*PAT*.*;*Sch*.*|*Full*.*"
    while ($True) {
        try {
            $synchronizationResult = $session.SynchronizeDirectories(
                [WinSCP.SynchronizationMode]::Local, $destPath, $sourcePath, $False, $transferOptions)
            $synchronizationResult.Check()
            Write-Host "Synchronization on folder $($destPath) succeeded!"
        catch {
            Write-Host "Exception catched while synchronizing the folder $($destPath)"
        finally {
            foreach ($transfer in $synchronizationResult.Transfers) {
                try {
                    Copy-Item Get-Content( $destPath + $transfer.FileName) -Destination Get-Content( $destPathNew + $transfer.FileName) -Force
                    Write-Host "Copy of file $($transfer.FileName) succeeded"
                catch {
                    Write-Host "Exception catched while copying the file $($transfer.FileName)"
    Write-Host "Waiting..."
    Start-Sleep -Seconds 5
finally {
    $session.Dispose()
sameer12
Pakistan
Thanks Admin Martin
Now the errors
go away finding another error
Exception catched while synchronizing the folder D:\ReplicationViaFTPServer\
Re: The value supplied is not valid, or the property is read-only. Change the value
That's your error, it does not say anything to us.
sameer12
Pakistan
HI Admin Martin,
Keep tried I am able to download the files successfully . The below code works for me, only the issue I am facing while running the script from Windows PowerShell. The Windows does not close after entering the log to sessionlog.log (file). Keep writing same information to session. In the picture attached I have only three files for testing purpose, but the it keep writing the duplicates to sessionlog.log. I want to stop writing duplication close Windows PowerShell after completing the downloads from FTP. Please help me out.
Add-Type -Path "WinSCPnet.dll"
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = "*****"
    PortNumber = 21
    UserName = "*******"
    Password = "******"
    FtpSecure = [WinSCP.FtpSecure]::Explicit
    TlsHostCertificateFingerprint = "5f:66:34:ad:e9:a9:8f:c2:60:79:d8:38:f6:da:7a:0b:68:d7:94:3b"
$session.SessionLogPath = "D:\ReplicationViaFTPServer\LogBackups\Sessionlog.log"
try
    # Connect
    # Transfer files
    $remotePath = "D:\FTP\*"
    $destPath = "D:\ReplicationViaFTPServer\*.*"
    $destPathNew = "D:\FTP\Caspio\"
    $transferOptions.FileMask = "*PAT*.*;*.TRN;*Sch*.*|*Full*.*"
    while ($True)
        try
            $transferResult = $session.GetFiles($sourcePath, $destPath, $False, $transferOptions)
            $transferResult.Check()
        finally
                $session.GetFiles($transfer.FileName, $destPathNew, $False, $transferOptions)
                Write-Host "Download of $($transfer.FileName) succeeded"
            $destPathNew1
finally
    $session.Dispose()
Description: Log keep writing the same files information continous
  • Sessionlog.log (85.95 KB, Private file)
Description: Session log information
The windows does not close after entering the log to sessionlog.log (file)
I'm not sure I understand.
The program/window does not close, as you have an infinite loop there:
while ($True)
