Windows Task scheduler action -> argument issue
bquac23
I am currently trying to automate a process of ftp-ing a file from my computer to an FTP server using Windows Task scheduler, WinSCP and adding in the commands in the argument section of "actions". The parameters I passed to Task Scheduler were as follows:
/log=c:\Users\xxxx\Desktop\linden\linden.log /command "open ftp://user:pass@ftpserver.com/" "put C:\test.txt /Observations/folder/" "exit"
It looks like the command executed fine and in the log I see that everything ran successfully. I attached the portion of the log for reference. But when I actually went into the folder to check the file is missing/not there.
Please advise!
bquac23
windows task scheduler action ->argument issue
Thanks for the input. After numerous attempts, I've gotten it down to one last issue. When i try to send the file, all the logs says that it was sent successfully but nothing appears on the FTP server. if i rename the file by renaming the file by adding a character, the file sends correctly. This also holds true if I remove a character while I rename. But I just can't ftp the file as is.
My current task scheduler command is the following:
/log=C:\PROGRA~1\destination path /command "open ftp://serverlogininfo" "put -latest C:\PROGRA~1\destination path\* /ftp/path/" "exit"
Please advise.
Re: windows task scheduler action ->argument issue
Maybe you have this "problem":
Why is uploaded file not showing in a remote directory or showing with a different name?
If not, please attach a full session log file showing the problem (using the latest version of WinSCP).
