Where is .exe after build?
branko1972
SI
I finally prepared the environment to specification to build from WinSCP-5.13.8-Source
Build finishes with:
Build succeeded.
0 Warning(s)
0 Error(s)
But after I check the directory tree there is no executable created only .dll
What am I doing wrong?
Re: Where is .exe after build?
Now I went line by line of build.bat and found some previous error nagging about UafxcW.lib
Then I copied this lib from C:\Program Files (x86)\Embarcadero\Studio\14.0\lib to ..\source and afterwards compiled with success! (only few warnings) working executables!
Which project/solution did you build?
You have to build WinSCP.groupproj/WinSCP.cbproj
