transfer.Options File Permissions
I'm trying to set the transfer options to ignore file permissions and timestamps but i'm still receiving the error back from the server:
code is here:
Any ideas why its not passing or being ignored by the server perhaps?
< 2019-02-28 10:23:16.188 Error message from server: This server does not support operations to modify file attributes. File attributes for [/Inbox/move_me.xml] were not modified.
* 2019-02-28 10:23:16.189 (ESkipFile) **Upload of file 'move_me.xml' was successful, but error occurred while setting the permissions and/or timestamp.**
* 2019-02-28 10:23:16.189 If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
* 2019-02-28 10:23:16.189 Permission denied.
code is here:
try { # Connect $session.Open($sessionOptions) # Set options, upload files, collect results $transferOptions = New-Object WinSCP.TransferOptions $transferOptions.FilePermissions = $Null $transferOptions.PreserveTimestamp = $False $transferResult = $session.PutFiles($localPath, $remotePath, $transferOptions) # Iterate over every transfer foreach ($transfer in $transferResult.Transfers) { # Success or error? if ($transfer.Error -eq $Null) { Write-Host "Upload of $($transfer.FileName) succeeded, moving to backup" # Upload succeeded, move source file to backup Move-Item $transfer.FileName $successPath } else { Write-Host "Upload of $($transfer.FileName) failed: $($transfer.Error.Message)" } } } finally { # Disconnect, clean up $session.Dispose() }
PS C:\Users\xxxxxx> $transferOptions PreserveTimestamp : False FilePermissions : TransferMode : Binary FileMask : ResumeSupport : default SpeedLimit : 0 OverwriteMode : Overwrite
