Right Click to transfer files
nice tool, nice work ;-)
But one little feature (I'm dev too - so I know it's a small one ^^)
Pls add the feature, that I can transfer files by right clicking them and select "Transfer" or sth similar. I don't like Drag-and-Drop cause all other Win Commander similar applications give me this opportunity.
It would be very nice if you could do this for me and the rest of the winscp community.
Regards [maG]
Re: Right Click to transfer files
There is "Copy" command in the context menu. Do you mean this?
Anonymous wrote:
oh I forgot, the opportunity to "Transfer files as" (means with other filenames / extensions) would be nice, too.
I do not understand this. Please explain.
Svatyulet wrote:
Ahoj ako sa da prihlasit do toho programu co mam za dat v menu Spojeni Hostitel?Dakujem
Server ke kteremu se chcete prihlasit.
