Local documents are not visible:
dareen
Abu Dhabi
Subject: Local documents are not visible:
Using WinSCP 5.13.5 with “Commander” interface on Mac OS X El Capitan, and the SFTP protocol the local files are not displaying on the left window. For example the desktop is empty only showing the WinSCP.desktop, any other documents or files of the Desktop are all not visible.
Reply with quote E-mail
Re: Local documents are not visible:
Your MacOS desktop is probably in a different path than the one Wine presents to WinSCP. Unfortunately I cannot help you further, as I'm not familiar with MacOS.
