Unable to create directory with subdirectorys using sftp
Bjoern
Germany
i need to create paths with subdirectorys, with sftp protocol it returns an error:
WinSCP.SessionRemoteException: "Error creating folder '/home/pdf/2019/1'.
No such file or directory.
The path "/home/pdf" already exists, but the subpath "2019/1" does not exist
When i am creating every single subdirectory in one step, it works. there is no need for until i am using the ftp prototol instead of sftp.
i am using Version 5.13.7, testing down to 5.13.3 and there is allways the same error.
i also testet different sftp servers (Synology, FileZilla Server, Webhosted SFTP) with the same result
is it a bug?
greetings :)
Re: Unable to create directory with subdirectorys using sftp
You cannot use Session.CreateDirectory method to create multiple levels of folders in one go.
