Upload through LAN
shechina
Western Hemisphere
Upload through LAN
I'm trying to use a folder on my LAN as my local (upload from...) directory, but the "Network" directory does not expand when I click it in the "Browse for Folder" box. Is this an issue at my end, or is this function not supported? Thanks!
Re: Upload through LAN
Can you post a screenshot of that problem? As well as a screenshot, where you have the drive expanded in Windows Explorer.
