Batch file -> How to keep window from popping up?
I am successfully using a batch file to download files from my ftp server. When it does so a window opens and see the name of every file being downloaded.
How do I keep this from showing up??
I do not want to see anything. I can get any info from the log file.
Hide output window
My batch file is as follows and I thought the echo off would do the trick.
@echo off
/command ^
"open ftp://anonymous:anonymous@10.19.1.100/" ^
"cd /" ^
"lcd ""C:\ILC""" ^
"get -delete S*.csv" ^
"exit"
Re: Hide output window
Redirect the output to nul:
@echo off
  /command ^
	"cd /" ^
	"lcd ""C:\ILC""" ^
    	"exit" > nul
Output window STILL there (but empty)
I added the > nul but the output window still appeared with title "anonymous@10.19.1.100 - WinSCP"
Nothing appeared in the window which I assume is due to the > nul.
Is there a way to keep this window from popping up at all??
Re: Output window STILL there (but empty)
I'm not sure I understand. You are running a Windows batch file. That batch file (not WinSCP) opens the console window. So do you want to run a batch file without a window?
Do you even need the batch file for anything? How do you run it?
fncruz
USA
FTP
Martin,
I want SCP to go to a FTP and copy all csv files then delete them. I believe that the only way to do this is to automate using a batch file to call up SCP. This in turn brings up the COS window.
I would like to have everything run invisibly without any window popup.
Can this be done?
Thanks.
FC
fncruz
USA
"Nothing you have written so far need a use of a batch file"
I do not mind having WINScp open and running minimized but I cannot see how to automate.
How can automation be done without batch file?
You run your batch file somehow - we do not know how - you have never told us.
A point of a batch file is to execute multiple commands. Yet your batch file has only one command - executing WinSCP. So the batch file is pointless. Instead of executing your single-command batch file, execute WinSCP directly - Replace execution of your batch file with execution of winscp.exe with the same arguments as you have in your batch file.
winscp.exe runs completely silently without any window.
https://winscp.net/eng/docs/executables
