Command Line Inteface Question
Tom Williams
When I am running long shell scripts on the server, I see a prompt that the server has not communicated back in 15 seconds with an option to abort or wait another 15 seconds.
Question 1
If I just ignore this prompt, will my script continue to completion and the shell will exit on its own?
Question 2
If the answer to number 1 is No, how to I prevent this prompt from showing? When I set Batch Mode On the script auto exits on the first prompt which is bad..
I'm using the December posting of WinSCP.
Regards,
Tom
Re: Command Line Inteface Question
Yes it should.
You can set longer timeout on login dialog.
Simon Tse
Yes it should.
I set a 999 timeout on the login dialog. But that doesn't actually save it does it? I have to save the 999 timeout to a specific session it seems like.
When I run the batch script to connect to a server, it still says timeout after 15 seconds. How can I set the default timeout to be higher so that the command line batch script for winscp can have a long timeout as well?
