Error when logging in
youradds
UK
I'm getting this weird error now when logging in on one of my server:
Command 'ls -la -d "25"'
failed with return code 2 and error message
ls: cannot access '25': No such file or directory.
It gets through the login process (up to "Starting Session"), and then it pops up and alert as above, and upon confirming it the WinSCP instance closes and I can't login :/
Any ideas?
Cheers
Andy
Re: Error when logging in
youradds
UK
Hi Martin,
Thanks for the reply. haha ironically, you asking me to enable logging, I realised I've had logging enabled since the last bug report I was doing! As such, I had an 800mb log file! After deleting it and turning logging off, it now logs me in fine! (and the general experience is faster as well - which is something that was getting a bit annoying before =))
Duh! Please consider this issue solved :)
Cheers
Andy
