Problems WinSCP to Arista Router
gil_happy
Hello, I seem to be having an issue when trying to WinSCP from my Window 10 PC to an Arista router.
When I attempt to connect using the correct username, password, and port number, I receive 2 error messages:
1) Host is not communicating for more than 15 seconds. Still waiting... Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
2) Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
The Arista router has a bash prompt and I believe the 'scp' binary is installed and executable.
Does anyone have any suggestions?
Thanks in advance!
Re: Problems WinSCP to Arista Router
gil_happy
Hi, thank you for the response... The router does indeed have a Linux like shell. If I go into bash, then do a search for 'scp', I see it under:
-rwxr-xr-x 1 root root 82420 Apr 12 2018 scp
Just as an FYI, I have a different machine (a Linux server) where I can successfully WinSCP to it and scp attributes are:
-rwxr-xr-x 1 root root 79880 Sep 12 09:46 scp
gil_happy
Good question.... once I ssh using port 22 to the Arista router, I enter the user / pass. Then from the terminal prompt, I put it into 'enable' mode (similar to a Cisco router), and then I type 'bash'. At that point I'm in the bash shell.
That first part of the login could be the problem.
