Redirection problem
Horst
Redirection problem
when I use winscp.com with cmd(win10) I can correctly open a connection, navigate and tranfer. But when I use redirection with the winapi(anonymous pipes) it seems I can successfully open a connection with a command, but every following command didn't work.
I hope somebody can help me
WinSCP, Version 5.13.6 (build 9061)
logg2.txt is the redirection with my program and logglvl2.txt is with windows cmd and winscp.com
BR
Re: Redirection problem
There seems to be 20 minutes delay before you send the help command:
. 2019-01-11 13:52:38.863 Timeout waiting for network events
> 2019-01-11 14:10:46.912 Script: help
The server probably closes the connection meanwhile.
Horst
Hi Martin,
The other logfile logg2.log after line:
„2019-01-11 13:54:44.189 Startup conversation with host finished.“
All the cmds like „cd / or help or other“ will not receive :-/
Horst wrote:
Hi Martin,
Do you mean that you send some commands to WinSCP using the "pipe"; and they are not received by WinSCP?
We cannot help you with that, as you didn't show us any code.
