Not all synced files in $synchronizationResult.Uploads (powershell) if remote subdir not exist
Henk50
Netherlands
I am new to WinSCP, but found the following (bug?):
I have modified this script: Deleting remote files after successful remote to local synchronization
to do it the other way around(upload).
It is working OK IF the destination directories already exists, but if not, ONE file in each directory (except in the latest directory) is missing in $synchronizationResult.Uploads, so that file will not be deleted from source directory. The synchronisation was OK, all files done. What's wrong?
My test source directory is C:\...\Postbus UIT\Test1\Test2\Test3
files in Postbus UIT: Test0.txt; Thimo 2015 Postvak_LUIT - Copy.jpg; Thimo 2015 Postvak_LUIT.jpg
files in Test1: Test1.txt; Thimo 2015 Postvak_LUIT_TEST2 - Copy.jpg; Thimo 2015 Postvak_LUIT_TEST2.jpg
files in Test2: Test2.txt; Thimo 2015 Postvak_LUIT_TEST_TEST - Copy.jpg; Thimo 2015 Postvak_LUIT_TEST_TEST.jpg
files in Test3: Test3.txt; Thimo 2015 Postvak_LUIT_TEST_TEST - Copy.jpg; Thimo 2015 Postvak_LUIT_TEST_TEST.jpg
After running the script: Test0.txt, Test1.txt, Test2.txt still exist in source directory.
It looks to be, that if the sync operation have to create a remote-directory, one file is missing/skipped in $synchronizationResult.Uploads????
Running latest version 5.13.6.
Any idea?
Source:
param (
    $localPath = "C:\TEMP\WinSCP_Test\Data\Postvak UIT\",
    $remotePath = "/Postvak IN/",
    $LogFile_Session = "C:\TEMP\SessionLogX.log"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\TEMP\WinSCP_Test\WinSCPnet.dll"
    # Setup session options
        HostName = ""
        UserName = ""
        Password = ""
        SshHostKeyFingerprint = ""
    $session.SessionLogPath = $LogFile_Session
    try
        # Connect
        # Synchronize files to local directory, collect results
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $false,[WinSCP.SynchronizationCriteria]::Time)
        # Deliberately not calling $synchronizationResult.Check
        # as that would abort our script on any error.
        # We will find any error in the loop below
        # (note that $synchronizationResult.Uploads is the only operation
        # collection of SynchronizationResult that can contain any items,
        # as we are not removing nor uploading anything)
        # Iterate over every Upload
        foreach ($Upload in $synchronizationResult.Uploads)
            # Success or error?
            Write-Host "==== Upload of $($Upload.FileName) ==="
            if ($Upload.Error -eq $Null)
                Write-Host "Download of $($Upload.FileName) succeeded, removing from source"
                # Download succeeded, remove file from source
                $filename = [WinSCP.RemotePath]::EscapeFileMask($Upload.FileName)
                Remove-Item($filename)
                if( -not $? )
                    Write-Host "Removing of file $($Upload.FileName) failed"
                else
                    Write-Host "Removing of file $($Upload.FileName) succeeded"
            else
                Write-Host (
                    "Upload of $($Upload.FileName) failed: $($Upload.Error.Message)")
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
  • SessionLogX - Copy.log (102.35 KB, Private file)
Description: Logfile of exercise above.
Re: Not all synced files in $synchronizationResult.Uploads (powershell) if remote subdir not exist
Issue 1715 – The last file transfer before creating a remote directory during synchronization is not reported with .NET assembly
Henk50
You've done a great job! Problem solved, many thanks!!
I like WinSCP and the powershell library very much.
