VBA FTP DOWNLOAD EXCEL
Narna
South Africa
I want to DOWNLOAD files using FTP within Excel using VBA.
I'm getting a "Connection Failed" error.
Any ideas what I am doing wrong?
(I am using FTP because I don't want to use Sftp which requires a SshHostKeyFingerprint.)
Sub DownloadFile()
    Dim mySession As New session
    ' Enable custom error handling
    On Error Resume Next
    Download mySession
    ' Upload mySession
    ' Query for errors
    If Err.Number <> 0 Then
        MsgBox "Error: " & Err.Description
        ' Clear the error
        Err.Clear
    End If
    ' Disconnect, clean up
    mySession.Dispose
    ' Restore default error handling
    On Error GoTo 0
End Sub
Private Sub Download(ByRef mySession As session)
    FTPServer = "ftp://host2.bakop.com/"    ' = Range("K6")
    FTPFolder = "STS Data"                  ' = Range("K7")
    FTPUsername = "utility"                 ' = Range("K8")
    FTPPassword = "Rosebud1"                ' = Range("K9")
   ' LocalFilename = Range("K10")
    LocalFolder = ActiveWorkbook.Path
    ' Setup session options
    Dim mySessionOptions As New sessionOptions
    With mySessionOptions
        .Protocol = Protocol_Ftp
        .HostName = FTPServer
        .UserName = FTPUsername
        .Password = FTPPassword
      '  .SshHostKeyFingerprint = "X"
    End With
    ' Connect
    mySession.Open mySessionOptions
    ' Upload files
    Dim myTransferOptions As New transferOptions
    myTransferOptions.TransferMode = TransferMode_Binary
    Dim transferResult As TransferOperationResult
    Set transferResult = _
        mySession.GetFiles("/" & FTPFolder & "/", LocalFolder, False, myTransferOptions)
    '     mySession.GetFiles("/" & FTPFolder & "/", LocalFolder & "\" & LocalFilename, False, myTransferOptions)
    ' Throw on any error
    transferResult.Check
    ' Display results
    Dim transfer As TransferEventArgs
    For Each transfer In transferResult.Transfers
        MsgBox "Download of " & transfer.Filename & " succeeded"
    Next
End Sub
Reply with quote E-mail
Re: VBA FTP DOWNLOAD EXCEL
A hostname is "host2.bakop.com", not "ftp://host2.bakop.com/".
What's pretty lame excuse. What wrong with SshHostKeyFingerprint?
