Any way of not forcing an auto connection to a site on program start up?
Frustrated
In the past all the FTP clients on Windows that I have used simply opened the app when you ran them via a shortcut. WinSCP is the first such client that forces you to select a connection to a site on the app start up. Is there any way of simply having the application start up without have to connect to a site?
Re: Any way of not forcing an auto connection to a site on program start up?
What would you do with WinSCP without an opened connection?
Frustrated
Perhaps try to import the 20 entries I have in my old SSH client without having to re-enter all the configuration information back into. If that miracle ever occurred then I would back that up into a non proprietary format.
I would like to also simply look through the features of an application without having to maintain a connection to an external site to do so.
The function to import a configuration is actually on the Login dialog only!
https://winscp.net/eng/docs/config#import
Most of the functions are disabled without an opened session.
