From network drive (shared with onedrive) to SFTP: System Error. Code: 267.
hungeri
Budapest / Hungary
Hi there,
I have a network mapped (Windows) drive (Z:\), on which I have a shared onedrive directory. This means I copy anything to this network drive's directory, it will be synced to a onedrive account.
Before the sync happens (or the onedrive service on host machine is down), I easily can copy files and dirs from this drive to an SFTP, but after the onedrive sync occured, I get this "System Error. Code: 267.". What exactly happens is that WinSCP creates every time a new directory (even when copying files!) on the SFTP side and after that comes this error message. I don't know the technique onedrive uses, but after sync all my files and dirs seems to be a symlink, but any other apps are working fine: I can copy files with the Windows Explorer, or with Total Commander and the more strange is that WinSCP handles them as a file when open or run them, the error occurs only when trying to copy or move...
Any ideas, what could be wrong?
Thx in advance!
Re: From network drive (shared with onedrive) to SFTP: System Error. Code: 267.
What version of WinSCP are you using? Can you try the latest beta version?
What you describe sounds like this issue:
https://winscp.net/tracker/1355
If that does not help, please post a full session log file.
hungeri
Budapest / Hungary
5.13.6 (build 9061)
Yes, 5.14.2 is installed and tried out. Unfortunately the result is the same:
Error retrieving file list for "Z:\OneDrive\Dokumentumok\(...)20902.pdf\*.*".
Please look at the end of the "pathname" (which should be a filename instead as you can see the pdf extension)...
Thanks for the patience, I did it. However it logged the version number as 5.13.6, however logging occured after installing the beta version. I restored the old ini file, maybe that caused this.
Then you are not running 5.14.2. Please try to install it again.
hungeri
Budapest / Hungary
I've found the trick, why it was not the beta. Now it is, result is same, session log attached. Thx!
  • session.log (52.21 KB, Private file)
