Using PutFiles() when remote folder is the root folder
CCC_RonM
United States
I'm using C# Session class to PutFiles() to a remote FTP site. I seem to be having trouble with the remotePath param. The folder on the remote site is the root folder so there is no sub path to enter here. I tried "/" and the transfer fails. I also tried just "" empty string. I had no more files to test with so I haven't tried just "/root" or something similar. What am I missing here? Thanks!
Re: Using PutFiles() when remote folder is the root folder
The slash is correct (assuming the account it chrooted).
Can you upload a file in WinSCP GUI? If you can, can you post a complete session log file showing that?
CCCRonM
Thanks for your reply. I was able to retest the code late in the day yesterday when a new file came in and I got it to work. the "/" was correct, as you said, in the first place. I'm still not sure yet why it failed before but it seems I'm good to go now. Thanks again.
