use android toolbox‘s “ls” command error
QwQ
Use winscp to access the android file system
toolbox‘s ls can’t work
busybox‘s ls can work
ERROR:
Unexpected directory listing line 'drwxrwxr-x system sdcard_rw 2018-12-04 22:27 .Android'.
没预计到的目录列表行'drwxrwxr-x system sdcard_rw 2018-12-04 22:27 .Android'。
toolbox’s ”ls -la“ :
root@android:/data/data/com.teslacoilsw.quicksshd/home # toolbox ls -la
-rw------- root root 3 2018-12-17 15:15 .ash_history
drwx------ u0_a112 u0_a112 2018-12-13 12:16 .ssh
busybox's "ls -la ":
root@android:/data/data/com.teslacoilsw.quicksshd/home # busybox ls -la
total 16
drwx------ 3 10112 10112 4096 Dec 17 07:15 .
drwxr-x--x 6 10112 10112 4096 Dec 15 21:36 ..
-rw------- 1 0 0 3 Dec 17 07:15 .ash_history
drwx------ 2 10112 10112 4096 Dec 13 04:16 .ssh
.png
Re: use android toolbox‘s “ls” command error
It seems that the output misses inode column. Cannot you use SFTP protocol instead?
QwQ
on android, do not have sftp,only scp
You can create an alias to the ls command what will add a (fake) inode column (using sed or something similar).
