Moving remote directories to desktop doesn't allways work
Bruno
Hi.
I want to report a bug. I usually move a directory from the server to my WinXP desktop, but it seldom works. Usually, the dir is downloaded but to a temp directory; it never appears in my desktop. However, sometimes it works.
I'm using version 3.76, but the problem was also present in a previous version, 3.6, I think.
Regards,
Bruno Martínez
Re: Moving remote directories to desktop doesn't allways work
Can you try to find out, when it works and when not? I suppose that you are not using the drag&drop shell extension, do you?
Bruno
I always do pretty much the same thing. I pick the folder in WinSCP, go to the taskbar so the desktop is shown and drop it there. I guess that qualifies as using the shell extension, right?
No. By shell extension I mean special feature of WinSCP. Please refer to documentation.
I understand now. I'm not using the shell extension. Good documentation, btw.
How can I help you track this down? I could attach a debuger, given instructions.
Still, I believe there must be something specific on the transfers that fail. Any idea, really?
