TLS Connection aborted during deleting files
LALILU
Germany
Hi Martin,
during deleting files, the connection to the ftp-server aborts by a TLS layer change.
Here the Debug2-log from the connection:
. 2018-11-28 10:04:51.996 Got reply 1 to the command 32
. 2018-11-28 10:04:51.996 Deleting file "/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset/from.iso-8859-13.ser".
> 2018-11-28 10:04:51.997 DELE /htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset/from.iso-8859-13.ser
< 2018-11-28 10:04:52.014 250 DELE command successful
. 2018-11-28 10:04:52.014 Got reply 1 to the command 32
. 2018-11-28 10:04:52.014 Deleting file "/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset/from.iso-8859-14.ser".
> 2018-11-28 10:04:52.014 DELE /htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset/from.iso-8859-14.ser
. 2018-11-28 10:04:52.032 TLS layer changed state from connected to aborted
. 2018-11-28 10:04:52.032 Verbindung zum entferneten Rechner abgebrochen
. 2018-11-28 10:04:52.032 Got reply 1004 to the command 32
* 2018-11-28 10:04:52.041 (ESshFatal) **Verbindung verloren.**
* 2018-11-28 10:04:52.041 Verbindung zum entferneten Rechner abgebrochen
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset/from.iso-8859-14.ser'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim/charset'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP/Shim'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork/PHP'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src/Patchwork'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8/src'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork/utf8'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty/patchwork'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei '/htdocs/nextcloud-13.0.8/3rdparty'.
* 2018-11-28 10:04:52.041 Fehler beim Löschen der Datei 'nextcloud-13.0.8'.
Regards
Re: TLS Connection aborted during deleting files
It's probably not TLS-related. It's rather that the FTP server simply closes a connection abruptly.
Does it happen always with the same file? Or randomly?
LALILU
It happens randomly.
Not on a specific file, duration or cycle of deletions.
I wrote my hoster already and waiting for their response of the server-logs.
