Script authenticates but file does not get copied
tyntema
This is my log ... Trying to figure out why this does not copy the file. I can manually copy. I've changed the file location, since it seems like a permissions issue, no luck. TIA
2018-11-21 14:45:23.444 Using SFTP protocol.
. 2018-11-21 14:45:23.444 Doing startup conversation with host.
> 2018-11-21 14:45:23.460 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2018-11-21 14:45:23.507 Type: SSH_FXP_VERSION, Size: 124, Number: -1
. 2018-11-21 14:45:23.507 SFTP version 3 negotiated.
. 2018-11-21 14:45:23.507 Unknown server extension posix-rename@openssh.com="1"
. 2018-11-21 14:45:23.507 Supports statvfs@openssh.com extension version "2"
. 2018-11-21 14:45:23.507 Unknown server extension fstatvfs@openssh.com="2"
. 2018-11-21 14:45:23.507 Supports hardlink@openssh.com extension version "1"
. 2018-11-21 14:45:23.507 We believe the server has signed timestamps bug
. 2018-11-21 14:45:23.507 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory
. 2018-11-21 14:45:23.507 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2018-11-21 14:45:23.507 Changing directory to "/cygdrive/d/copssh/home/mf-melbourne-us/Payments".
. 2018-11-21 14:45:23.507 Getting real path for '/cygdrive/d/copssh/home/mf-melbourne-us/Payments'
> 2018-11-21 14:45:23.507 Type: SSH_FXP_REALPATH, Size: 60, Number: 16
< 2018-11-21 14:45:23.569 Type: SSH_FXP_NAME, Size: 123, Number: 16
. 2018-11-21 14:45:23.569 Real path is '/cygdrive/d/copssh/home/mf-melbourne-us/Payments'
. 2018-11-21 14:45:23.569 Trying to open directory "/cygdrive/d/copssh/home/mf-melbourne-us/Payments".
> 2018-11-21 14:45:23.569 Type: SSH_FXP_LSTAT, Size: 60, Number: 263
< 2018-11-21 14:45:23.616 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2018-11-21 14:45:23.616 Getting current directory name.
. 2018-11-21 14:45:23.694 Listing directory "/cygdrive/d/copssh/home/mf-melbourne-us/Payments".
> 2018-11-21 14:45:23.694 Type: SSH_FXP_OPENDIR, Size: 60, Number: 523
< 2018-11-21 14:45:23.741 Type: SSH_FXP_HANDLE, Size: 13, Number: 523
> 2018-11-21 14:45:23.741 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2018-11-21 14:45:23.804 Type: SSH_FXP_NAME, Size: 379, Number: 780
> 2018-11-21 14:45:23.804 Type: SSH_FXP_READDIR, Size: 13, Number: 1036
< 2018-11-21 14:45:23.861 Type: SSH_FXP_STATUS, Size: 28, Number: 1036
< 2018-11-21 14:45:23.861 Status code: 1
> 2018-11-21 14:45:23.861 Type: SSH_FXP_CLOSE, Size: 13, Number: 1284
. 2018-11-21 14:45:23.861 ..;d;0;2018-10-09T11:29:53.000Z;3;"mf-melbourne-us" [10018];"Users" [545];rwxr-xr-x;0
. 2018-11-21 14:45:23.861 munis to mobileeyes.txt;-;3957;2018-11-21T15:03:30.000Z;3;"mf-melbourne-us" [10018];"Users" [545];rw-r--r--;0
. 2018-11-21 14:45:23.898 Startup conversation with host finished.
Re: Script authenticates but file does not get copied
Please post your script and attach a full session log file showing the problem (using the latest version of WinSCP).
Solved - the log file path was incorrect and I believe this was the problem. Please delete my post.
