Can i use put statement and synchronize statement in the same script.
Saradevi
USA
Hi martin,
Can i use the put statement and synchronize statement in the same script on the same file while uploading to remote server.Will it cause the system to fail and gives an Error Code 4.
Thanks,
Devi
Re: Can i use put statement and synchronize statement in the same script.
You can, but it makes no sense. What are you trying to achieve?
