Is there option to cut paste command to transfer local file to remote server
siddhesh_007
mumbai
Dear Team ,
Thanks & Regards
Siddhesh Dhotre
Re: Is there option to cut paste command to transfer local file to remote server
You can copy a local file to clipboard from a file system context menu (by default accessible using "System Menu" command in built-in WinSCP file context menu).
In WinSCP 5.14 beta, you can use standard Ctrl+C shortcut:
https://winscp.net/tracker/316
To paste local files copied to clipboard to remote directory, use standard Ctrl+V or Paste command (supported in all recent versions).
