Default column width are HUGE!
spookycave
All - is there a way to prevent the default column widths in winscp navigator to be so big that you have to scroll for miles to get to the column you want to see?
Mike
Re: Default column width are HUGE!
Do you have this problem, when you start WiSCP with the default configuration?
winscp.exe /ini=nul
