Make WinSCP the top most window on startup
clyfton
Florida
Is there an option somewhere to make WinSCP be the top-most window when it is started?
Every other program I run comes to the top when I start it. It is strange behaviour and annoying that I have to dig out WinSCP from under other windows every time I start it. I looked for an option but could not find.
Re: Make WinSCP the top most window on startup
WinSCP should behave as any other application in this respect.
How exactly do you start WinSCP? Can you post some screenshots documenting the problem? What version of Windows are you using? Do you have some extensions installed in your Windows desktop/shell?
clyfton wrote:
I don't remember how I created the shortcut, it was years ago.
I can delete and recreate it if there is a preferred method.
Please do. Use "Pin to taskbar" function.
OK, I'm sorry, I do not know how to help you. I've never seen this problem before and I do not know what else to look for.
