Powershell - Download folders from ftp with wildcard
CptDuckie
Netherlands
Hi all,
I'm using a Powershell script to auto download updated files from an FTP directory, im using the synchronisation method for this. I want to be able to specify a directory with a wildcard. Like
folder /download/software/version/4*. Or be able to download everything with folder /download/software/version/400 and higher. I want to do this, because there are older version, ex. version 100, 200, 300 which won't need to be downloaded, exact 400 and higher.
Is there any way to realise this? Currently using this script:
# Specify directories
$localPath = "C:\Temp\Software"
$remotePath =  "/Download/Software/Version/"
    # Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP-5.13.4-Automation\WinSCPnet.dll"
try
    # Setup session options
        Protocol = [WinSCP.Protocol]::ftp
        HostName = "download.ftp.com"
        UserName = "anonymous"
        Password = "anonymous"
    try
        # Connect
        Write-Host "Connecting to FTP..."
        # Download files
        Write-Host "Synchronizing changes..."
        $transferResult =
            $session.SynchronizeDirectories(
                  [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $false. $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Downloads)
            Write-Host "Download of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
If I add a wildcard to the /Download/Software/4* directory it fails with the following error:
PS C:\temp> C:\Temp\DownloadSoftware.ps1
Error: Exception calling "Check" with "0" argument(s): "Error listing directory '/Download/Software/4*'.
The filename, directory name, or volume label syntax is incorrect. "
CptDuckie
Netherlands
      # Download files
        $transferOptions.FileMask = "| 10*/; 20*/; 30*/; 40*; 410*; 411*"
        $transferResult =
                  [WinSCP.SynchronizationMode]::Local, $DownloadPath, $ExactVersion, $false, $transferOptions)
If I do it like this, it seems to ignore the filemask/excluded files and still downloads everything starting by 10.. Did I configure the filemask or fileoptions wrong?
The above is wrong.
Though even your wrong code does not explain the behavior you are seeing.
Use one of the examples I've suggested. If it does not work, please attach a complete session log file.
CptDuckie
Netherlands
I have changed it to
$transferOptions.FileMask = "| 1*/; 2*/; 3*/"
and for example, it starts downloading folder 397. Which should be excluded.
Here is the session.log. I have filtered out a few details.
Description: session logfile
