Automation scripts to transfer files.
Salongec
United States
I am working on a project where I have to send several files to several different offsite locations. All the reports will be pushed down to a local SFTP server and then I need to automatically transfer these files to 4 different remote SFTP servers. This is a daily and monthly occurrence. I am in need of assistance in creating a script that automates this task. Currently, I open WinSCP and individually transfer each report to the appropriate folder. I have found scripts where I should be able to do one report at a time, but I have not found anythng that will do more than one report with a different name at one time. Is this even possible?
Re: Automation scripts to transfer files.
Just repeat the put command for every file (report).
It would help, if you post the script that you refer to. It may illustrate better, what you are trying to do. And you may get more concrete answers.
