Remote window host uses GMT
gkoproske
Local window is CST. Remote window host time uses GMT. Thus, I need to find a setting for the remote window to reflect the GMT time -6 hours. Where can I find this?
Re: Remote window host uses GMT
You might be looking for Time zone offset settings.
https://winscp.net/eng/docs/ui_login_environment
But WinSCP should usually autodetect the difference. Please attach a full session log file showing the problem (using the latest version of WinSCP).
